CDI Box/Rev Limiter
Old Aug 12, 2004 | 04:02 PM
DSengineer's Avatar
Has been here a long time!
Default CDI Box/Rev Limiter
Both the Viper DS and the BajaX should have the same stock CDI/rev limit of 7900RPM's. I'm not sure why some say they are different because I don't believe they are, or would understand why Bombardier would do that. Doesn't make sense to put a different rev limit on the same motor.
Old Aug 12, 2004 | 11:45 PM
berksglh's Avatar
My procom CDI box is less then 6 months old, and the DS just started running like total crap. Tried everything, then swapped in tthe stock CDI in place of the procom unit. WOW! It was like a preformance upgrade? Thats right, the stock unit was way up on power as compared to the procom unit. And my backfire went away.... It wasnt allways like that, the procom unit was an increase over stock when i first got it.
I aparently got a so so unit that gradully went bad over time. It seemed down on power, then started backfirring up north 3 weekends ago for no reason, and i was way down on top end power the whole day.
Ridding at the track the following weekend i found out it was a bad procom CDI, Changed to the stock unit and now it runs fine.
I havnt contacted procom yet to see if they will back there product with an exchange or refund yet..... Otherwise i have a 100 dollar rifle target to bring to the rifle shooting range and get my money out of it from 300 yrds with the 25-06...
Old Aug 13, 2004 | 12:15 AM
lilnotts's Avatar
Originally posted by: Baja2002
My CDI was modified last winter. I have the stock CDI with a new curves and 9400rpm cut off.
Very great.
Only 125$ CAN for the modification [img]i/expressions/face-icon-small-smile.gif[/img]
would you mind sharing some info about that modification?
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Sep 17, 2015 03:06 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
