Lectron 46
Entomber,
There is a screw to adjust the low end air/fuel mixture, it sounds like you need to turn that a little. That screw will also affect your idle speed, so you will have to re set the idle after you change it. One thing I suggest before you make any changes, take the quad for a really good 'hot lap' and then play with it. When it is fully warmed up it will be easier to adjust. This will also give you a very fresh idea of what you are trying to change.
#18
For a car that would be high, since they idle at like, 750. However the DS normally idles at 1300-ish so 1800 - 2000 isn't that bad. When you hear one idling at 1800 vs. 1300, you can tell a difference in sound, but it is still certainly an idle and only a bit faster - it doesn't sound like it should be running down the track at that point. My 2001 is at 1300 (Stock) and my 2003 (Lectron) is at 1800 (I think.)
#19
I've noticed you do need to have the idle a bit high on this carb. That air/fuel mixture screw, how do you go about adjusting that. The more I turn out the higher it revs up. I think I need to turn the metering rod one more turn in. I've tinkered with both idel and mixture screw and its still a bit hesitant on the way low bottom. It seemed to be more responsive from when I got it from MisterHP, than what it is now since I tinkered with it.
I think I may need to turn the fuel metering rod to richen up a bit. When I turned it 2-3 turns more in it was responsive but the exhaust was showing a bit of coloration, prob too rich. I didn't mess with the air fuel screw tho. I think I will try that this week.
