nitrous install (pics)
Wow! That system looks great. I have a few more questions now that I have actually seen one. Is that the best place for the bottle? How long will a big bottle like that las?
When I get mine done I'd like for it to be slightly more incoginto(sp). Is it possible to "hide" the equipment? maybe a smaller bottle, and position guages and pumps under/behind plastic?
After-all the speed of miy bike has to make up for a lot of rider de-effinciency.
Yea you could hide it and put the bottle anywhere you want, just as long the siphon tube is correct when the bottle is mounted. I get about 6-7 good passes out of a two 1/2 pound bottle. I always try to run the selonoids to the nozzle as close as possible, the closer they are the harder it hits. I wouldnt want to mount them real far away like on the bumber or something. You would just have to mount it the best way that you like.
You can definatley see the difference between runs in your times without a heater. Each pass starting with a full bottle without a heater will be slower due to the pressure decreasing. Some guys run thier heaters with a thermostat type setting, others have theirs with a switch and a turn the heaters on manually and watch the pressure. It dosen't hurt anything to run without the heater just remember you will be getting slower as the pressure drops.....
Amd, Your set- up looks very clean and I agree keeping the solinoids close is a plus. I will try to get some pictures of one of my set -ups on here soon. The bottle is in the same place but everything else is mounted differently.
As far as keeping the system more stealth that is easy.... The hardest part is locating the bottle in a place that is secure, They sell the small stealth bottles but then your only going to be good for a few runs. All my components are hidden except for the BIG BLUE BOTTLE. But I want to make sure I can play for a while without running out.
I never use a heater, I just use a torch and heat the bottle up. LOL just joking guys, never use a torch. lol I use a heater on my 10 pound bottle for my car I thought about just using it, but that is just another switch and wiring to do.
jrooker6
Apr 23, 2016 07:36 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
