Best lube for cables?
Old Sep 7, 2004 | 01:11 PM
MudStud's Avatar
Default Best lube for cables?
I want to lube up my throttle cable. I dont know if wd40 is the best option??
What is the best thing to use?
Old Sep 7, 2004 | 02:23 PM
Hightower's Avatar
I use bel-ray cable lube made for cables, along with a cable luber that clamps around and seals to force the lube into cable sleeve and purge the old out the other end. I use it on clutch and throttle
Old Sep 7, 2004 | 02:27 PM
MudStud's Avatar
yea, I just went on RMATV and bought the tust cable luber and then a can of cable lube.. only cost me 12 bucks [img]i/expressions/face-icon-small-smile.gif[/img] It will be done right...
Old Sep 7, 2004 | 02:43 PM
BigBadScrambler's Avatar
I use Tri-Flow on everything from cables, to chains, to tie rod ends. Stuff works GREAT!. Protected with teflon[img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
Old Sep 8, 2004 | 02:30 AM
busmechanic's Avatar
I am not sure who makes the stuff I use. could be belray. its called "cable life" it came with the clamp tool.
Old Sep 8, 2004 | 11:34 PM
raidermike67's Avatar
WD 40 isn't good for much as a lubricant. It's what they use to displace ice on airliner wings.
Whitelx1
Oct 2, 2015 10:55 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
craacker
Sep 9, 2015 04:32 AM
bmark0610
Sep 7, 2015 09:42 PM
