NEED HELP ELECTRICAL GUYS
GUYS....... I DID NOT THINK I WOULD GET IT BUT FOR THOSE WHO SAID IT WAS A GROUND PROBLEM......... YOU DA MAN!!!.. AFTER A FEW HOURS OF TINKERING AND CHECKING CONNECTIONS AND USING A DREMEL TO SAND DOWN THE POWDER COATING TO BARE METAL FOR THE GROUND WIRES I GOT IT. THANKS A TON TO EVERYONE WHO REPLIED . YA'LL ROCK. I ALSO FOUND OUT THAT ON A DS THE CONNECTION SWITCHES (ALL OF THEM ) STEM FROM THE GROUND. ON A REGULAR LIGHT SWITCH THE SWITCH ITSELF CONNECTS THE POSITIVE WIRE AND DISCONNECTS IT AS YOU FLIP THE SWITCH WHICH IS PRETTY MUCH HOW MOST STUFF IS HOOKED UP. NOT ON THE DS . IT IS THE OPPOSITE JUST A TIP FOR THOSE WHO EVER HAVE TO MESS WITH THE WIRING. ANYWAY THANKS AGAIN.
toonces
Oct 16, 2019 12:11 PM
ranvette
Jul 4, 2015 06:13 PM
