where is the fuse for the fan?
my fan isnt coming on and i checked the switch on th eside of the motor when it is cool it has juce on one terminal when it gets hot it has juice on both terminals so i think it might be the fan or the fuse?
well i just pulled my fan out and ran a 12v positive and negative to it from the battery and it would not start until i turned it with my hand, i checked my leads and it is getting 12.75 volts, i have tried it 20 times and each time i had to give it a bump with my finger to get it to start, now i am reading the threads about the fan from autozone im trying to find the part number so i can go pick one up, you guys saved me money again, this forum rocks
now that i think of it my nuetral switch does not work so i think i am gonna run a hot wire from the fan switch to my green nuetral indicator on the dash so now everytime my fan comes on my green light on the dash will light up, that will work right?
Yes and no...LOL
Your idea will work if the green lamp is good. But you said the netural switch doesn't work. Do you say that because the green light doesn't come on?
Any way you may already know this but....the wire that goes along side of your oil filter is the ground leg for that netural light. It is fasned to a spot just under the filter with a very small philips head screw. If yours is not...then that may be why your not getting a green light while in netural
well i just got don checking my neutral light and found out it was bad lol, i thought the switch in the tranny was bad so i ordered a new one for 9 dollars from my dealer so now i can tell when it is neutral nice,
