What tire/rim sizes do you recommend??
Old Nov 28, 2004 | 10:25 AM
Dragorus's Avatar
Default What tire/rim sizes do you recommend??
I need new tires and I might as well get the rims tooo.....What would you recomend for a stock replacement or even what is a better size to run on a DS650 baja?....I foud it too hard to get the tires i want due to the factory rim & tire size. I do alot of trail riding in ocala florida....Also want to correct the steering shake at high speeds....I have a set of TBR a-arms I'm looking into getting.
Old Nov 28, 2004 | 12:17 PM
JMAC650's Avatar
I would go for 10x6 douglas 190's with 23" itp holeshot HD front, and 10x9 douglas 190's with 22" itp holeshot xct rears. You should change your front sprocket to a 15 tooth to bring the gearing close to stock with the bigger tires.
I ride 99% trails and tracks and this setup works the best out of all the tires iv'e tried.
Old Nov 28, 2004 | 01:39 PM
Dragorus's Avatar
Same size front and rears...Was thinking of getting the c series wheel.....What is a good site to get them at....
Old Nov 28, 2004 | 03:36 PM
BillDS650's Avatar
They due not make the C-series for the DS bolt pattern of 4-143
Old Nov 28, 2004 | 04:10 PM
JMAC650's Avatar
You will want the 23's in front & 22's in rear for trail riding. They give you more clearance then the stock size. It's like the DS was made for 22's and 23's. I would never go back to stock size myself.
Old Nov 28, 2004 | 06:23 PM
Dragorus's Avatar
so the only rim I can get is .190's?? also do they make the HD's holeshots for the front's?...where is a good place online to buy them??
Old Nov 28, 2004 | 06:32 PM
JMAC650's Avatar
You can get 125, 160, & 190. Don't waste your money on the others they will bend and dent. The 190's are the strongest rims. Look at my photo's, I have 23" HD fronts and 22" XCT rears.
Old Nov 28, 2004 | 06:34 PM
jiffy's Avatar
i recommend 23 inch front tires. holeshot xct's and 22 inch rear mud machines. best tires i have ever had. would never buy anything else.
jeff
Old Nov 28, 2004 | 06:37 PM
JMAC650's Avatar
Try www.rockymountainatv.com. They have the best prices and tires are usaully in stock.
Old Nov 28, 2004 | 06:43 PM
Dragorus's Avatar
What are the exact dimensions i need to order for the front 23's and rear 22's....Also They don't seem to make an HD model fronts.....
