Bad Luck
Old Dec 4, 2004 | 05:00 PM
BillDS650's Avatar
Default Bad Luck
If I did not have bad luck I think I would have no luck at all. I got all the parts for the new axle and the stock sprocket hub for the DS650 does not fit on the DuraBlue axle both are for the 05 models. Time for more calls Monday.
Old Dec 4, 2004 | 08:34 PM
CountryJoeGlass's Avatar
Default Bad Luck
[img]i/expressions/face-icon-small-sad.gif[/img] That sucks. I hope you get everything worked out & let us know how it goes.
Old Dec 5, 2004 | 05:54 AM
BOMBSAINT's Avatar
Default Bad Luck
sounds like something that would happen to me. first you brace yourself to tear apart the ds. then you cant wait to get it back up, then when you think you will be riding, smething you wait forever for is wrong and you go to bed that night dreaming of riding and wantin to choke some salesmen who left out that little piece of info that could have saved you a month. i have been there..... wait a minute...... i am there! works shocks better get there shi## together![img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Dec 5, 2004 | 12:55 PM
BillDS650's Avatar
Default Bad Luck
Things I have had bad luck with and lost money.
1. The place I bought my DS from total rip-off. I have stopped doing businesses with them.
2. Custom-X exhausts. It was Heavy, loud expensive.
3. Sam Coe all most blew up my engine but got it fix just before he closed shop.
4. MBRP did not work.
Things that work great but took extra work or extra time too get working.
1. TCS shocks the best but it took about 4 months to get the new rear spring for my old fat body.
2. PPD Racing air box had to cut off corner to fit Graydon Proline pipe.
3. Graydon Proline pipe my own fault it work great but I messed it up making too many changes to it.
4. TBR, Just do not do businesses just before a big race.
5. IMS Gas tank just took extra time for them to finished design.
Thing that just work
1. Edelbrock 42mm QS carb
2. Parts from Ron Wood
3. Parts from On Dunes Performance
4. Vortex CDI
5. Sand Tires from Daryl Smith Sand Tires and Fullerton Sand Tires.
Thing still working on but looking good
1. Fox float air chocks
2. DuraBlue
3. Pingel fuel valve.
Old Dec 5, 2004 | 11:26 PM
lilnotts's Avatar
Default Bad Luck
YA! MBRP! WOOOOOO! lol
Old Dec 7, 2004 | 11:16 AM
BillDS650's Avatar
Default Bad Luck
DuraBlue came through they are sending me a new sprocket Hub. The first run of the 05 DS650 axles were off on the Sprocket side.
Old Dec 10, 2004 | 11:45 AM
BillDS650's Avatar
Default Bad Luck
I got the new sprocket hub yesterday from DuraBlue at no cost. I still can not believe someone admitted to a mistake and fixed it, thank you DuraBlue. Now I just have to get a tougher socket to get the brake rotor off. I have busted one. Bombardier locktite is some tough stuff to brake lose and cheap socket due not help either. (I did heat up the hub first.)
Old Dec 11, 2004 | 09:26 AM
BillDS650's Avatar
Default Bad Luck
Bad luck still with me hub did not work sending axle back today
Old Dec 11, 2004 | 04:17 PM
R00ST's Avatar
Default Bad Luck
man..i forgot about my MBRP... that thing sucked. was the loudest pipe i ever had (louder than my open hmf) and had power on par with stock.... (didnt somebody on here dyno with that pipe on and LOSE 12 hp? it was awhile ago, forgot who it was, i think it was a 720/760)
Old Dec 11, 2004 | 06:41 PM
JEFFROE's Avatar
Default Bad Luck
yes my 760 lost like 12hp w/mbrp pipe, it sits up stairs in storage slowly rotting away.
p.s. mbrp pipe for sale[img]i/expressions/face-icon-small-disgusted.gif[/img]
