How many lbs should i run in my Extreme Haulers
Old Jan 9, 2005 | 06:24 PM
c-daddy's Avatar
Default How many lbs should i run in my Extreme Haulers
I just got 20-10-10 extreme haulers how many lbs should i run in them?
Old Jan 9, 2005 | 06:47 PM
1BigDSRider's Avatar
Sand conditions are a huge thing to consider when your deciding on what tire pressure. I run between 5-7 on my 22's extremes. Start with higer tire pressure and work down until you start hooking up. Its easier to deflate then add air.
Old Jan 9, 2005 | 06:51 PM
c-daddy's Avatar
hey "1bigdsrider" where do you ride at (if anywhere) around shreveport? I go to La Dunes but is there anywhere Closer?
Old Jan 9, 2005 | 08:01 PM
maddog56's Avatar
I run an even larger range, 3-13. The sand drag track gets watered down a lot and the sand gets very heavy.
Old Jan 9, 2005 | 11:29 PM
Cumdaddy, I usually ride At the Dunes. There are alot more riding areas around the Tyler, Tx area several riding venues.
MikeyBoyesq
Sep 22, 2015 10:02 AM
01ssls1
Sep 22, 2015 06:50 AM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Elkaholic
Sep 6, 2015 02:44 PM
