Pipe
Old Jan 21, 2005 | 03:07 PM
Steveo10's Avatar
Default Pipe
FMF Powercore 4. Just got it. Haven't installed it let. Is it a good pipe or not? I got a jet from FMF and will it make a big diff. if i don't use it? thx
Old Jan 21, 2005 | 07:55 PM
JMAC650's Avatar
Default Pipe
What mods do you have? What elevation are you at? I have the same pipe and my jetting is at 172.5 mikuni main, needle in the 4th groove from the top, 45 pilot jet, and mixture screw at 2 1/4 turns out. I am at sea level.
Old Jan 24, 2005 | 01:26 AM
Steveo10's Avatar
Default Pipe
'01 DS
K&N
FMF PowerCore 4
and just installed a speedo today which isn't much of a mod.
Elevation. ummm don't know, prairie Alberta
I just installed the pipe about 2 hours ago. I never did re-jet the quad. I haven't done a thing to the carb. Don't know much about the carb beside what it does...lol I did it at my dads shop which there isn't much of place to ride. I just rode it down the street. I don't think the motorst liked the noise. Sounds great altough. Maybe just b/c i'm use to the normal/quiet factory sound.
Is the pipe suppose to give me mostly lower-end power. And not much of a top-end?
Old Jan 24, 2005 | 01:39 AM
JMAC650's Avatar
Default Pipe
170 to 172.5 main jet. Needle in the 4th groove. THis should work for you. When you take off the bowl to do the main jet change the 4 screws the stainless allen head bolts. It will make it much easier to get in there again. The sizes are 3 4x10mm & 1 4x12mm. On the needle just take off the gold colored cover on the top of the carb. Take out the slide and remove the needle. Be careful not to loose the washers or spring and remember how they are on the needle. Put the clip in the 4th position and put it back together. Set the mixture screw about 3 1/2 turns out. Should be pretty close.
Old Jan 24, 2005 | 01:41 AM
thumper650's Avatar
Default Pipe
what do you men needle 4th groove
Old Jan 24, 2005 | 02:24 AM
Steveo10's Avatar
Default Pipe
Ty JMAC for the info. I will try to follow the instructions.
Old Jan 24, 2005 | 02:34 AM
TheChosenOne's Avatar
Default Pipe
Elevation at about 2200 ft, i run trinity stage 4, 190 ain lid off, needle 4th from top i believe. If you notice any bogging or popping, your jetting's out. Maybe one of these days if I'm up there and ya need a hand I can swing by.
Old Jan 24, 2005 | 02:52 AM
Steveo10's Avatar
Default Pipe
Ya, i guess you only live like 45 min from me chosen 1. For the few minutes that i rode it, everything seemed to run good. I'll take it out for another run tomorrow. But i normally don't run my quad in
-5celcius weather. more like +15.
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
bvolks
Sep 13, 2015 12:57 PM
