Wide band oxygen sensor??
Old Jan 31, 2005 | 07:42 PM
crackerJack's Avatar
Default Wide band oxygen sensor??
I have done several searches to try and find a wide band Oxygen sensor LCD display and cannot find anything that is for an exterior application and works for a wide band. It has to be a WIDE BAND display. I keep finding the car applications. I also already have the oxygen sensor and only want the lcd display. Has anyone ran across one or know where I might find one?? Thanks for the help
justin
Old Jan 31, 2005 | 08:46 PM
ScoobyDFW's Avatar
there are a couple, but very pricey, around $1000.
there might be a do it yourself kit that is cheaper - i.e. build the circuit board yourself.
what sensor do you have? Bosch LSM-11? Bosch LSM-4 UEGO?
you might be better off using an EGT gauge.
after your repeated piston damage, I'd be thinking there might be an air/fuel ratio problem, so you need one gauge or the other.
Old Jan 31, 2005 | 11:19 PM
ds650ratrider's Avatar
This is solution, but needs a PLX controller:
click me
This is the required controller:
Click me now.
I'm with Scooby, I'd get a exhaust temp gauge first. At least then you can safely switch fuels.
Old Feb 1, 2005 | 12:28 AM
Majorecho just welded in another bung and hooked up the normal O2 sensor and the 79$ gauge. He has two bungs but alot less money. at that price I think I will go Majorecho's direction. I was worried if the egt would give me some false readings due to the turbo being so hot. Maybee the turbo does not cause any different fluxuations in the exhaust gas temps.
Old Feb 1, 2005 | 12:45 AM
OverRaTeD's Avatar
Runs a DS870 that will flat out Shit and Git!
Here is one with data logging that you can pull up and graph according to rpm. Also they are coming out with a digital dash gauge too. It is wide band and can also be plug into a dyno.
Clicky
Old Feb 1, 2005 | 11:40 AM
DuneMe's Avatar
Interesting. . . Controller to me means it gives some sort of signal output to do something??? Is it meant to send a proportional signal to an EFI???
Old Feb 1, 2005 | 10:10 PM
The EGT works great on turbo diesels.[img]i/expressions/face-icon-small-smile.gif[/img] I wonder how easy it is to tune on a dune versus a dyno with the EGT. My A/F gauge is silly easy, but I only run unleaded.
Old Feb 19, 2005 | 09:59 PM
sixsixT's Avatar
This one looks good and is priced right. A/F display
Old Feb 19, 2005 | 10:23 PM
ScoobyDFW's Avatar
here is another for $349: http://www.innovatemotorsports.com/products/lm1.php
looks like prices have come down.
i'm trying to figure out if range of these meters/sensors is wide enough for alcohol.
OOPS, already posted above.
(I just checked the documentation on the LM-1 and you can use it with methanol).
Old Feb 21, 2005 | 11:22 AM
Prozack's Avatar
So what if you run race fuel such as VP Red or C-12 ? Does that render the sensors useless ?
