ds800??
Old Mar 9, 2005 | 10:16 PM
fast69's Avatar
Default ds800??
my gears were stock at first it was late sat we changed to 15 and dropped psi to get her to hook up better. my ket is HP research.
Old Mar 9, 2005 | 10:20 PM
thumper650's Avatar
Default ds800??
cool jw how much did you spend on you 800kit. do you have an extened swing arm and if do how much
Old Mar 9, 2005 | 10:27 PM
DemonDS's Avatar
Default ds800??
When you changed to the 15th, were you going from a 14th? Or were you looking for second gear starts? Generally if you cant catch traction on your launches you should move your gearing up, not down, or start from the next higher gear. Just curious.
Old Mar 9, 2005 | 10:33 PM
fast69's Avatar
Default ds800??
I have A + 6 how much$$$ ???wood have to add it all up pad for it at different times little by little over 9 or 10 month.
  #15
JDsBusa's Avatar
Default ds800??
Yeah, I agree if you cant make it in traction with a better tire make up for it in wheel speed.
Justin
Old Mar 9, 2005 | 10:49 PM
  #16
fast69's Avatar
Default ds800??
We were spinning the tire to much it was late sat when we changed gear we also changed tire psi down we waited to late too started to try to get out of the hole better to try one thing at a time we will take her back out to try out differnt set ups.
Old Mar 9, 2005 | 10:57 PM
  #17
thumper650's Avatar
Default ds800??
twll me the best set up
Old Mar 9, 2005 | 11:03 PM
  #18
fast69's Avatar
Default ds800??
we will have to see ? what works best .she has too much power for what i had befor.
Old Mar 10, 2005 | 02:05 AM
  #19
thumper650's Avatar
Default ds800??
are you (fast69) going to dune fest in oregon wichesterbay
Old Mar 10, 2005 | 11:47 AM
  #20
BIGBAJA's Avatar
Default ds800??
16/38 works great for the 800
