Dyno runs
Old Mar 31, 2005 | 03:01 PM
crackerJack's Avatar
Default Dyno runs
DSsleuths machine is not showing those numbers due to a kind dyno either. I was lucky enough to ride it at Sand Mountain and it is the strongest stock bore aspirated machine I have ridden. All the addons work together well.
Old Mar 31, 2005 | 04:28 PM
sandbomber's Avatar
Default Dyno runs
Originally posted by: 1BigDSRider
Sandbomber, were you running duels, lectron, or other carb on your 770?
dual fcrs
Old Mar 31, 2005 | 05:55 PM
1BigDSRider's Avatar
Default Dyno runs
When Eric took your bike and tuned it, how much did he get on his dyno???
Old Mar 31, 2005 | 06:20 PM
sandbomber's Avatar
Default Dyno runs
That was my 720 Mike, I would hate to give out bad information and just dont recall the details enough to post[img]i/expressions/face-icon-small-blush.gif[/img]
Old Mar 31, 2005 | 09:18 PM
  #15
SANDMAN430's Avatar
Default Dyno runs
that was cheap hp dssleauth
Old Mar 31, 2005 | 10:08 PM
  #16
CountryJoeGlass's Avatar
Default Dyno runs
Originally posted by: DSSleuth
I'm am running a Hi comp Piston in the stock cylinder, shim under valve, 110 cams, stock carb, MBRP slip on pipe, K&N filter, stock air box w/ the lid on, vortex ignition.
the 760 is all Pami, The 770 is all TVI, both bikes have the same carb. I don't know what the exact differences are.
Once I get the a-arms back from the chrome shop I will put my wife's 720 on the Dyno!!!!
I'll ask Gary what the base line is, because I don't know.
DSSleuth what I ment by base line was what you were running in your bike to get the 55HP & you anwered that. Nice job & thanks for the info.
Old Apr 1, 2005 | 12:34 AM
  #17
DSSleuth's Avatar
Default Dyno runs
Sandman, your right
CountryJoeGlass, glad it got cleared up!
Old Apr 1, 2005 | 01:18 AM
  #18
SANDMAN430's Avatar
Default Dyno runs
hope i find some of that 3 dollar hp.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 1, 2005 | 01:36 AM
  #19
sandbomber's Avatar
Default Dyno runs
If I know you, You will!!!!!!!!!!!
Old Apr 1, 2005 | 08:21 AM
  #20
thebigshow's Avatar
Default Dyno runs
i imagine with the nos, yours is going to throw down a pretty rightious number. im kind of curious to see how much difference your 11 to 1 piston then a 13 to 1 puts up. ought to be interesting...
