Lectron done need jetting
Old Apr 22, 2005 | 08:08 PM
jbracer's Avatar
Default Lectron done need jetting
Well after another weekend of the lectron sticking, this time getting me a titanium bar from my elbow to my shoulder put in, I'm going back to stock for awhile. Need to know jetting for 14:1, no airbox just tube, exhaust and cams. Will possibly consider efi this winter.
Old Apr 22, 2005 | 11:38 PM
1BigDSRider's Avatar
Are you talking about sticking wide open??? Are you using a cable boot?
Old Apr 23, 2005 | 02:25 AM
LuvTheBomb's Avatar
I switch between my Lectron and my stock carb depending on whether I'm riding dunes or trails. I have about the same setup as you and when running the stocker I use a 190 main and the needle on the richest position. I don't have an exhaust yet (very soon[img]i/expressions/face-icon-small-smile.gif[/img]) so you maybe could use a 195.
Just a note on your lectron, I've had mine stick before (I call it cruise control), fixed it by making sure my cable was routed and lubed properly. Have you talked to Mr. HP about it?
Old Apr 23, 2005 | 04:11 PM
flyinds's Avatar
i had a sticking problem this winter with my lectron and the problem was the moose thumb throttle . the lever inside was hitting the case on back inside i filed the lever a little and it don't hit anymore. you might want to check that.
Old Apr 25, 2005 | 11:22 AM
BasicBajaX's Avatar
Keeps busy in the garage building one thing or another.
My Moose throttle was rubbing in the same place. Now it is stock feeling with no stuck shut problem.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
