Running hot!!!
Old Jun 9, 2005 | 11:41 PM
theanimal's Avatar
Default Running hot!!!
Ok heres the deal. I had a dead battery so I jumped my DS off and let it idle. It sat there idling for about 20 min and when I checked on it, coolant was overflowing and the temp light was on. I took it for a ride around the block and it finally cooled down enough for the light to go off.
My question is, has anyone else here had probs with overheating? Oh and the fan was running.
Old Jun 9, 2005 | 11:46 PM
jackass650's Avatar
are the fins on your radiator plugged with mud?
Old Jun 11, 2005 | 12:34 AM
theanimal's Avatar
No the bike is literally spotless!! It doesnt make sense to me, I guess the bike just doesnt like the Houston heat.
Old Jun 11, 2005 | 02:48 AM
OregonDunePatrol's Avatar
Hmmmm. Shrouds and some inline coolers? They dont normally overheat with the fan on.
Old Jun 12, 2005 | 01:26 AM
theanimal's Avatar
Now this is at a dead stop in my driveway, no reving and the only air movement is from the fan. I dont see how shrouds would help when the bike is just sitting. I have never had the bike run hot on me before. Maybe i just shouldnt let it sit there and idle any more. oh well thanks guys
Old Jun 12, 2005 | 02:02 AM
sandbomber's Avatar
Your fins can be the problem even if you think it is spotless!!!! trust me on this one, been there!!
Old Jun 12, 2005 | 04:07 PM
Air's Avatar
Air
Stuck Thermostat.
Old Jun 12, 2005 | 05:40 PM
quadloco1's Avatar
You know its funny you should bring this up. I just got back from the dunes and my quad was running hot the whole time, Then all of the sudden the battery was dead and it wouldnot hold a charge. I'm wondering if its possible if the stator is trying to charge the battery so hard that it causes the motor to overheat. Just a theory.
Old Jun 12, 2005 | 05:45 PM
Well another idea (besides clogged radiator fins) might be a broken or partially broken impeller or impeller blade (water pump).
Old Jun 13, 2005 | 11:44 AM
Crash0000's Avatar
Also check the rubber boot between the carb and intake. If it is cracked, it will draw air and cause it to run lean and very hot!!!
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
