hole below the oil filter ds650 2000
mobil1 your not talking about the neutral switch are you? below the oil filter and in front of the contershaft sprocket are you? it has a black plastic peive that is screwed into the side if the case with a liitle bronze or brass hole that os threaded for the wire to attach? let us know what you find out
So, nobody know what is it ?? My dealer thinks that's it's a bolt that goes in there (M6x65)
It may not be so much that we don't know. . . it may be more that we aren't sure what you are attempting to explain [img]i/expressions/face-icon-small-blush.gif[/img]
First, if the oil filter cap is on can you see the hole?
If the filter cap is off and the filter is out the hole is. . . in the middle, in the ???? o'clock position???
The hole is about how large?
With this information we should be able to help you.
