Tectometer
Old Jun 24, 2005 | 07:08 PM
BioWare's Avatar
Toxic Ryder
Default Tectometer
I have a new ds650 bombardier, Can you use any tectometer, Can't I just buy one from a auto store and put it in. Or does have to be from the dealer. Open to any idea's..
Thanks....[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 25, 2005 | 02:19 PM
DuneRider650's Avatar
I ride a little here and there......
Default Tectometer
Tachometer... yes you prob could buy one from a automotive store but the easy way to do things would be to just buy the bombardier factory one and bolt her up.
Old Jun 25, 2005 | 03:49 PM
jackass650's Avatar
Default Tectometer
I may be wrong and someone please correct me if I am but I am pretty sure I have read a few past posts about the tach on our ds650's using the stator or the rectifier output to regulate the tachometer, do a search, that is why you have to buy onefrom bomb for 125.00 and not one from napa for 41.00, once again someone please correct me if I am wrong but I am 95% sure on this, let us know how it works out,
Old Jun 25, 2005 | 05:47 PM
Majorecho's Avatar
Default Tectometer
the tach gets it's signal from the coils as they fire, we have a wasted spark system so it fires every time the piston approaches TDC , if you pick up one from a different source it is mostly likely for a 4-6 or 8 cylinder engine and the signal will not be calibrated to give you an accurate rpm indicator. IT needs to be a tach specifically designed for a single cylinder/wasted spark system.
Old Jul 3, 2005 | 11:46 PM
Bajafred's Avatar
Default Tectometer
I have a perfectly good tachometer off of an 03 baja. $50 plus shipping should cover it.
Bajafred
Old Jul 4, 2005 | 12:01 AM
lvsparky's Avatar
Default Tectometer
fred what other parts? i need a tach!!
thanks sparky
Old Jul 7, 2005 | 01:24 AM
Bajafred's Avatar
Default Tectometer
The other guy wants the tach as well, you can have first chance. as for other parts I have an air box, complete motor, wiring harness, baja fog lights, stock grab bar, complete ron woods pipe, that's all I can think of for now. Bajafred@***.net Later
