Rolled Traxter, help!
Old Jul 1, 2005 | 12:26 AM
Jake519's Avatar
Default Rolled Traxter, help!
well anyways i was driving along, and hit one of those huge anthills which caused the front wheels to turn really sharp right into a ditch, luckly i jumped off before it rolled completely into the ditch. so finally i got it rolled back over, it didnt start to great but i managed to get it up the ditch then had to tow it home. There was oil in the airbox and the rear brake seems loose, any advice would great,
thanks,
Jake
Old Jul 1, 2005 | 12:49 AM
Jake519's Avatar
also the handle bars were bent down so i bent them back up, my ankle sprained and back hurts from trying to roll it back over, other than that the quad looks ok, please give advise on getting it to start and the brake problem
thanks
Old Jul 1, 2005 | 05:08 PM
Jake519's Avatar
anybody?
Old Jul 1, 2005 | 05:12 PM
SuzukiRiderz450's Avatar
Well the oil in the airbox is normal for a bad rollover...happened to me on the Outlander when I ran over a small tree (ended up somehow lifting 680 pounds right on me...), just give it a good cleaning, check the fluids, blah blah, etc. etc. As for the brake prob, check all the lines and brake fluid, anything could have happened.
Old Jul 3, 2005 | 03:44 AM
axlr8or's Avatar
Good luck man. I've got a Quest 650, and it stopped running after I hit a bump. I bought the factory service manual, and to no avail. I've even purchased 500 dollars in parts that I hoped would be the problem. Last part? another 500 dollars.
B dropped support of its older quads like a turd. I hope you get yours running.
fd24
Jan 16, 2019 08:59 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Albertaboyy
Sep 9, 2015 09:51 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
lancemll88
Sep 6, 2015 03:03 AM
