Fueltroubles??
Old Aug 1, 2005 | 12:48 AM
hansand's Avatar
Default Fueltroubles??
My Bombardier quest 650 is running perfect when the engine is cold, but after the first 4-5 minutes it starts not to take full rpm's and backfire will start? Does it need carburator adjustments?
Old Aug 1, 2005 | 11:47 PM
Scatterbrain's Avatar
Check to make sure that your choke is pushed all the way in. There are two notches on the choke. I have had the same problem with the stock carb.
Old Aug 1, 2005 | 11:49 PM
Oops you were talking about the quest 650 not the DS sorry. Im not Scatterbrain for nothin[img]i/expressions/face-icon-small-blush.gif[/img]
Old Aug 2, 2005 | 12:03 AM
DuneMe's Avatar
Make sure your gas tank is venting. If the vent hose has become pinched that may be the cause.
Old Jan 6, 2011 | 12:16 PM
scania's Avatar
Default hi
if your problem is like mine have you tried getting it hot then switch it off and back on then does the bike run ok for a bit if you have carb trouble there is a tiny gauze in the bottom of the carb that some times gets blocked
