DS Steering Shaft Removal??
Old Sep 12, 2005 | 11:08 PM
CaRider67's Avatar
Default DS Steering Shaft Removal??
I rolled my DS back in Feb, bent the steering shaft right near the top where it goes into the frame. My buddy and I managed to bend it enough to ride and I can't really notice much of a difference, but when I look at it it is just off a bit and it annoys the crap out of me. I want to remove the shaft and make it straight. Any advice? I read somewhere the nuts at the base of the shaft are a bear to get off or something like that?
If anyone has removed one and if you could give me some pointers I'd appreciate it.
Thanks
Mike
Old Sep 13, 2005 | 12:25 AM
DuneMe's Avatar
Do a search. I think JMAC650 has done this before.
Roll Custom Stem
Old Sep 13, 2005 | 03:40 AM
BillDS650's Avatar
You are going to have to remove the gas and oil tank, head light and dash. 13mm nut on bottom of oil tank by shaft is a pain to get off and back on.
Old Sep 13, 2005 | 07:15 AM
pads's Avatar
I did the exact same bend as you did. The above post was right about things to remove. I also found it easier to take shaft down through the frame. This means removing the a-arm skid plate. It is tight and the cables up top will give you some grief. Plan some time.
Old Sep 13, 2005 | 12:16 PM
Coyoteman's Avatar
It's a bitch. Like Pads said, plan on spending some time changing it out. I too found it easier to take the shaft down through the frame. Good luck.
Old Sep 13, 2005 | 05:25 PM
mudnuri's Avatar
I too had to fanagel it down and out. I had to stand on the bumper to get the arms the right way.
BillDS650 said it about that nut&bolt behind the oil tank. A universal extension will help. Patience too.
Old Sep 13, 2005 | 05:32 PM
JMAC650's Avatar
I replace mine with the Roll design one. You have to custom order a head and stem and have it welded together.
I rolled mine once since the roll design stem was installed and it didn't bend. I think it has to do with the stem being stronger and it has rubber mounted bars which have some give to them. The stem only cost me $100 from roll design.
Old Sep 13, 2005 | 10:04 PM
CaRider67's Avatar
Hey, thanks for the responses. Sounds like a bit of a project. The real bitch is I'm only about a half inch or less off. It was bent pretty bad to one side and after some creative leverage we got it ALMOST there.
Old Sep 14, 2005 | 03:04 AM
newbomber's Avatar
Here is an earlier post of how I have done it.
Fri July 01, 2005 7:55 PM
I have done mine twice and I think both times I blocked up the front tires and flattened the A arms and angled it out the bottom. The top piece goes through the bottom easier than the bottom piece does through the top.
Old Sep 14, 2005 | 04:21 AM
newbomber's Avatar
?????? Safecents, did you read the thread title????? Why are you pushing a new motorcycle company on a thread about steering stems??????????
You can start your own thread if you like!!!!
