bouncing off the rev limiter!
Old Sep 22, 2005 | 11:13 PM
chirochris's Avatar
Default bouncing off the rev limiter!
well i finally got my ds running---installed a new procom hi perfromance reg/rec(keep fingers crossed), new battery(sun),
end cap and K&n with prefilter..
first of all i didnt install the 175 jet but it seems to run great, no problems--- should i leave it?
my question is this...i am hitting the rev limiter real fast it feels like every gear in the pits and definetly while
we were dragging, i am not use to the new increase..its so quick
does not jetting have anything to do with this? and what will a ported intake do to this situation?
sounds like i need a CDI...higher rev, i just cant beleive how much of a difference the endcap and stuff made its like day and night
Old Sep 22, 2005 | 11:17 PM
650VIPER's Avatar
Yep, you needs to get you a higher reving cdi. There's lots to choose from. Glad its running for ya!
Old Sep 23, 2005 | 09:47 AM
Oldmanracing's Avatar
Great to see your back and running.
If you have the stock 165 mikuni, you are fine.
Stock cdi and endcap do not require major jetting.
You may want to raise your carb needle to the 5th/lowest from top of needle groove.
With endcap they hit strong in mid and you may want to richen that area up.
You can either change your plugs or pull out the outside plug and see what it looks like.
If the end of plug is dark(black) and the porcelan is still white or slightly tan - OK
If porcelan is getting dark brown all over - rich
If end of plug is clear and you see small metalic dustlike on porcelan - Lean
When you have some time read my post - Stock Carb Mods
Old Sep 23, 2005 | 09:54 AM
choosetolose04's Avatar
You can either do what Viper said or try changing your gearing to compensate for that extra power that your experiencing. This will help out with bouncing off the CDI...or you could just shift the bike a little sooner. LOL!
Old Sep 23, 2005 | 11:25 AM
chirochris's Avatar
i was trying to shift sooner but i guess i am not use to it yet, i just kept bouncing----
oldman i read that post last wk and have yet to try and mess with my carb cause i am not that handy with carbs!
i will soon, but i think i will pul the plug and look at it and see....should i pull it after i ride or when?
oldman thanks for all your help with eveything,,expecially the procomm reg--so far so good, we will see tommorrow cuase i havent started it in 1wk and i never could leave it for that long
Old Sep 23, 2005 | 02:55 PM
Freakneh's Avatar
If you do decide to purchase a different CDI, be sure to look in the, "What's in your garage" thread. I bought my RWR CDI from a member for $120.
J.
Old Sep 24, 2005 | 12:05 AM
chirochris's Avatar
vortex is the only way to go in my opinion
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Ahtatu
Sep 28, 2015 12:14 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
