Does it mater which way ? ( Front Sprocket)
Hey guys I noticed my front sprocket was wearing a little so I flipped it over. Does this matter? One side is a liitle recessed out more than the other but it seems to run fine. What do you think? Thanks, D
I believe the sprocket is different on the sides is because it holds the sprocket away from the case; hence the chain away from the case. I wouldn't do it.
Originally posted by: Topper I believe the sprocket is different on the sides is because it holds the sprocket away from the case; hence the chain away from the case. I wouldn't do it. edit: I just checked and rocky mountain has 14 thu 16 tooth primary drive sprockets in stock and they are less than 15 bucks[img]i/expressions/face-icon-small-smile.gif[/img] |
