Pilot Jet Size
Old Dec 23, 2005 | 05:06 PM
RotaxsRok's Avatar
Default Pilot Jet Size
Just picked up a 45 pilot and when I hold it side by side with the 40, the holes in the 45 look smaller, is this a mix up from the dealer or am I just confused? Shouldn't the 45 have larger holes?
Old Dec 23, 2005 | 05:13 PM
DSNUT's Avatar
Do they have their size inscribed on the side? If so I would trust the numbers on the side more than I would my eye.
Old Dec 23, 2005 | 05:14 PM
DSNUT's Avatar
Why are you replacing your pilot jet?
Old Dec 23, 2005 | 05:25 PM
RotaxsRok's Avatar
I am installing a HMF slip on with spark arrestor only and from what info I have gathered it seems as though most are running a 45 pilot and about a 165 main, I plan to put a 165 or 167.5 main in it, I am running at about 4500-6500 ft elevation the majority of the time. Also on one of my last trips out the temp was at about 15 deg and it was hard starting when cold, that was the main reason for going to the 45 pilot
Old Dec 23, 2005 | 05:29 PM
RotaxsRok's Avatar
Yes the numbers are scribed on the side, and there is a noticable difference in the size, is it possible that they gave me a different brand? Possibly a dynojet or something else.
Old Dec 23, 2005 | 05:50 PM
Oldmanracing's Avatar
Mikuni jets are flow tested. Very accurate. Flow is not only diameter, but length of diameter.
DJ are by physical size(diameter) only.
Old Dec 23, 2005 | 07:12 PM
RotaxsRok's Avatar
Thanks for the info, in went the 45 pilot and on went the HMF, also went with the 167.5 main. Just got back from a short ride up the street and I must say it really seemed to have more umph on the bottom and mid range, if this weather stays as warm as it is I may just have to load em up and head for Little Sahara, Utah over the Christmas break and do a little fine tuning. Oh by the way, that HMF is loud!!!! Gotta love it. I guess there is always the quit core option if needed, but for now I'm just going to enjoy that "Rotax Rumble". Thanks again[img]i/expressions/face-icon-small-smile.gif[/img]
Levi Enstad
Sep 26, 2015 08:00 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
rgjackson
Sep 23, 2015 01:53 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
