help 911
Old Dec 27, 2005 | 09:29 PM
2BIG2BFAST's Avatar
Default help 911
Installed the sprag, sprag housing flywheel, everything looks good but everytime i tighten housing bolts the starter locks up. loosen the 4 bolts ontop of housing starter works. [img]i/expressions/face-icon-small-confused.gif[/img]
Old Dec 27, 2005 | 09:59 PM
crazypainter's Avatar
Default help 911
gasket is compressing too much. I had a severe stator cover leak one of the mechanics at work gave me a gasket eliminator to try and the same thing happened to me. Loosen the top bolts about a half a turn and everything is fine. Or the washer is on the wrong shaft.
Old Dec 27, 2005 | 10:13 PM
2BIG2BFAST's Avatar
Default help 911
you are correct on guess # 2 washer on wrong shaft thanks.[img]i/expressions/face-icon-small-blush.gif[/img]
