Bent axle?
Old Jan 5, 2006 | 04:52 PM
mudnuri's Avatar
Default Bent axle?
I bent my axle a little bit during practice. I noticed it felt a little wobbly. I looked down and saw my wheel moving around. Back at the pits, I jacked it up and put it in gear to see if it was my wheel or my axle. The axle won. It seems to be bent only towards the hub where the axle gets skinny.
I have to use the rear wheels to actually "hook" a tree and pull the front around and between trees. This happens pretty fast so it's no wonder it's bent.
I imagine after a while the bearings will be affected, but will it cause damage to my carrier? Or any other parts?
I have a race every weekend for the next 2 months. I just don't know if I should continue and buy after Feb is over or stop and order a new axle?
Old Jan 5, 2006 | 06:18 PM
Oldmanracing's Avatar
Default Bent axle?
Axles can be straighted, you just got to ask around in your area.
Here in Wisconsin I use this shop.
http://www.totalperformance-llc.com/index.asp
He repaired mine for $50.00
Old Jan 5, 2006 | 06:33 PM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
Default Bent axle?
I would order a new one they are very easy to replace the only bad part is that you need to take your old axle and your new axle to a machine shop to have the sprocket hub pressed off your old one and pressed on your new one.
Old Jan 6, 2006 | 04:06 PM
mudnuri's Avatar
Default Bent axle?
Thanks oldmanracing and Tpsycho.
My dealer will sell me a new one for $202. I have a big press.
I found a place here that will straighten for $75
Hmmmm??
Old Jan 6, 2006 | 08:03 PM
dabomb03's Avatar
Default Bent axle?
I say get it straitened then when it bends again (and it will) then order a new one. I bent mine in the same place as you did and it was fine then after I clipped another tree it bent again. So thats when i got a new one.
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
1000gade
Sep 9, 2015 04:41 PM
Albertaboyy
Sep 9, 2015 09:51 AM
meddy0388
Sep 9, 2015 06:41 AM
bmark0610
Sep 7, 2015 09:42 PM
