EPIC A-arms
Old Mar 3, 2006 | 09:43 PM
CALDS650's Avatar
Default EPIC A-arms
[img]i/expressions/face-icon-small-disgusted.gif[/img]The Epic A-arms for the DS650 are not the best design and they due not use castle nut with cotter pins. I was very lucky I was coming to a stop when it fell apart. I ask if they had any castle nuts that would fit and they say use more loctite. It seams that they due not care about rider safety to me. I was able to find some in about ten minutes at a nuts and bolts shop.
Old Mar 4, 2006 | 01:10 AM
Fourwheelphreek's Avatar
Default EPIC A-arms
that was one thing i did notice on mine, but i have not had a problem yet with them, mine did come with ny-lock nuts though
Old Mar 4, 2006 | 04:29 AM
CALDS650's Avatar
Default EPIC A-arms
So did mine not good enough there race DS650 had castle nuts.
Old Mar 4, 2006 | 08:47 PM
CALDS650's Avatar
Default EPIC A-arms
Took the A-Arm apart and I think the noise was from the lower King Pin not being fully seated. I have taken it apart clean and reassembled it. The top half can use castle nut from DS650 ball joint. The lower ones I found are too thick going to try nuts for YFZ450 ball joint. The top ball joint I am going to have to wait for a month till some new ones get in with castle nut. I will just ride my Outlaw for the rest of the season.
Old Mar 4, 2006 | 11:15 PM
Default EPIC A-arms
ill have to look at mine tomorrow, i know i didnt get the usuall ones that epic sells, cause ryan made a set especially for me with the swingarm, might actually be the same ones he uses on the race team, they do look beefier then the ones i sell at my shop, and much better construction and welds
Old Mar 9, 2006 | 09:50 PM
CALDS650's Avatar
Default EPIC A-arms
I now have castle nuts all around it might be safe to ride again. I did not get the YFZ450 nuts I got LTZ400 castle nuts and they fit perfect. If EPIC got off there lazy rear and look you can find many places that had them in bulk. I guess EPIC does not care about rider safety just money.
Old Mar 9, 2006 | 10:54 PM
Default EPIC A-arms
did your pins come pre drilled for cotter pins? i looked at mine and i couldnt really tell, but when i installed them i didnt notice any.
Old Mar 10, 2006 | 04:33 AM
CALDS650's Avatar
Default EPIC A-arms
Top A-arm I had to get new Ball joint from Ishock. My lower pins are pre drilled. If yours are not drilled just keep checking them each trip to be safe.
XxS0ccerstarxX
Aug 31, 2015 04:47 AM
XxS0ccerstarxX
Aug 27, 2015 07:40 AM
musselmark
Jul 17, 2015 02:40 PM
