swingarm play
Old May 17, 2006 | 11:09 PM
matts01ds650's Avatar
Default swingarm play
so i was riding my wheeler and i could hear this clunking noise.....got it into the garage and it turns out my swingarm has some side to side play and is making the noise....i tried to to tighten the swingarm bolts but no dice...still makes the noise....anyone know of anything i can do...is it harmful if not taken care of???
Old May 18, 2006 | 08:24 AM
Majorecho's Avatar
there is a manual adjusting nut on the right side of the axle it's the large clamping nut you turn with your hand. Just loosen the nut and take the slop out of the bearings by tightening it, I like to put the rear end on blocks while I'm adjusting it to make sure that I still have good free play in the bearing and that the axle spins feely with outthe slop. Riding with the bearing too loose will damage them, might be a good idea to pull the axle out and inspect and greese them if you feel you can't get them adjusted right.
Old May 18, 2006 | 09:49 AM
KaylasDaddy's Avatar
Has been riding one thing or another since I was 11 years old.(31 years).
the bolt may have gotten loose & during the time it was you may have worn the broze bearing carriers whitch hold the side play. if you replace those you should also replace the bearings. the whole set of bearings &bushings cost $ 90.00 from the dealer.
shimanok2
Jan 29, 2016 07:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
