nos setup ?'s
#154
The vacuum carb sounds like a loss in signal. That happens with nitrous if the carb is on the bigger side for the engine na. Like a 48 on a 650.Yea you can run them and they work, but if it relies on vacuum it will already suffer a weak signal and nitrous only makes that worse.
