How freely should the rear axle spin?
Old Aug 24, 2006 | 12:53 AM
DSengineer's Avatar
Has been here a long time!
Default How freely should the rear axle spin?
I was installing my 520 chain/sprocket setup last night and had the chance to spin thre rear axle with nothing on it (wheels/tires, chain, brake caliper,etc) and something sure doesn't feel right. It spins smoothly (no grinding, or noise) but just feels really tight. If I grab the wheel hub and give it a good twist it comes to an immediate stop and takes quite a bit of force just to get it moving. Is this normal or do I have a problem?
Old Aug 24, 2006 | 01:24 AM
Dingo2's Avatar
DS..I'm far from an expert, but I just changed my bearings/seals and before I put the tires.wheels back on, I thought the same thing, didn't seem to spin as easily as I would have thought. My buddy said it seemed all good and when I finished her up, with rims on, it spun as good or better than his newer DS..You should be OK.
Old Aug 25, 2006 | 12:07 AM
DSengineer's Avatar
bump...
Old Aug 25, 2006 | 12:14 AM
650VIPER's Avatar
I guess it depends on the hand that twists it. I tighten it until I have no more side play in the axle, then just a little more. This should make it spin a little if you twist it hard. It wont spin freely though, as the grease should be packed in there good enough to slow it down. I would say your ok, as long as when you twist it, it isnt hard to do. It should move easily, with about................oh................rrrrrrrrrrr gggggggg that much strength,lol!
Old Aug 26, 2006 | 12:58 AM
DSengineer's Avatar
Well I'm happy to say I found the problem. The axle nut was on WAY too tight. I backed it out about a 1/4 turn and man what a difference. The dealer that greased the bearings under recall about a year ago was the last to touch it. So much for putting your faith in a certified Bomb mechanic. [img]i/expressions/face-icon-small-frown.gif[/img] I guess that is why I like to do everything myself. Just wish I had found the problem earlier.
1986Vmax540
Jul 9, 2021 09:53 PM
STLyamwar
Jul 25, 2020 04:44 AM
bigred20653
Aug 31, 2015 12:41 PM
DeFox500
Aug 14, 2015 05:59 PM
Rider252
Jul 6, 2015 03:37 PM
