starting
Old Nov 30, 2006 | 08:00 PM
grayrider28's Avatar
Default starting
I haveing a problem starting my ds. I have to spend the motor for like 30 mins or so(untill motor is hot) before it will even try to start.Once it starts and warms up,will start every time i hit starter.Anyone have any ideas>?
Old Dec 1, 2006 | 10:36 AM
Default starting
Has noone had this problem??Mabey adjusting the valves will do it?Have no clue how to do it or where to get the shims..
Old Dec 1, 2006 | 11:29 AM
bombrider04's Avatar
Default starting
I would have to say that the valves need to be adjusted, also putting the choke on doesn't help it start any easier. You can pick up the shims at a local bomb dealer just tell them the size you want.
Old Dec 1, 2006 | 07:14 PM
BioWare's Avatar
Toxic Ryder
Default starting
I would replace the plugs too while your at it....
Old Dec 2, 2006 | 11:21 AM
MRDS650's Avatar
Canadian and Proud of it !!!
Default starting
Yes
I have had this problem myself before and have seen it in other DS's. The bike needs to have the valves adjusted. If you are comfortable you can do it yourself - search valve adjustment on here I am sure it has been covered a couple of time. Otherwise take it to a dealer, it will run you about $200-300 bucks to have it done.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
