Idiot light problems, thanks OMR your mods work great.
Old Feb 12, 2007 | 10:32 PM
hagensmail's Avatar
Default Idiot light problems, thanks OMR your mods work great.
I have the red temp/oil light staying on. I have checked these forums, and found several ideas. But I was wandering if any one has had similar problems on there 2004 650 ds. I have a Pro Com CDI, OMR's carb mods, modified tip on factory pipe. Other than that bike is factory. I have looked into the oil tank, and the radiator both seem to be moving, or showing flow. The fan does work, I checked it, I just don't know which way to go next. Any advice would be greatly appreciated. Also I would like to thank OMR. Your mods work fantasticly. I can't thank you enough.
Old Feb 12, 2007 | 10:39 PM
JMAC650's Avatar
Unplug your oil pressure sensor under the carb on the motor. If the light goes out thats it.
Old Feb 12, 2007 | 11:58 PM
hagensmail's Avatar
I was hoping that wasn't the problem. You wouldn't know how much one would cost? would you
Old Feb 13, 2007 | 12:02 AM
hagensmail's Avatar
Was also wandering my shop manual is for the older models but it says something about having to split the engine. That's just if you want to get at the check valves right, I hope.
Old Feb 13, 2007 | 12:29 AM
FatHolly's Avatar
It's probably just the sensor... maybe $10 for a new one. If you get a bunch of watter in the sensor it will fry it. I keep a couple on hand just in case.
Old Feb 13, 2007 | 01:00 AM
JMAC650's Avatar
$10 to $12 at the dealer. You don't have to split the engine. Just look under the carb, it is a brass looking sensor screwed in the engine with a wire out of the top of it.
Old Feb 13, 2007 | 01:23 AM
hagensmail's Avatar
thanks FatHolly and JMAC650 I'll give that a try.
Old Feb 13, 2007 | 01:55 AM
cynick's Avatar
I had this same problem while at the dunes in Winnemucca, I figured it to be my sensor also cause when I unplugged it the light went out. Just for curiosity I pulled the sensor out and started the eng and no oil came out. I got lucky and shook the bike and got whatever was in the oil pump to fall out, just found out this last weekend when I split my cases to fix my shift forks that there was some aluminum that went into my pump.
Try pulling out the sensor and make sure you are getting oil, if not it could get expensive like I found out.
Seth
Old Feb 14, 2007 | 12:50 AM
hagensmail's Avatar
Thanks for all the help, I'm about a 2 hour drive to the shop I bought it from. Not to mention they aren't bombardier dealers. There is a dealer closer but I promised that jentleman that I would never ever darken his door step again. He had me waiting for a slide for my carb for over 3 weeks, telling me that he had it ordered. Only to find out he hadn't even made the call yet. So I thank everyone who posted addvice. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 14, 2007 | 12:00 PM
FatHolly's Avatar
I think you can use one out of your local auto parts shop. I'm not positive but I think I saw a thread here where someone used one from like Kragen or something. Do some searches for "oil pressure sensor"... it might be worth a try instead of a 2 hour drive. Also you could order it... try robsperformance.com or bikebandit.com they both have online OEM parts.
