I HAVE O4 BAJA X WITH A FEW ELEC. ISSUES,NEWBIE,PLEASE HELP...
Old Mar 4, 2007 | 04:33 PM
cass's Avatar
Default I HAVE O4 BAJA X WITH MANY ELEC. ISSUES,NEWBIE,PLEASE HELP...
HI, NEW TO SITE,I HAVE PURCHASED A O4 BAJA X.I ABSOLUTELY LOVE IT.THE RIDE IS UNBELIEVABLE, AND HAS GREAT POWER,BUT MINE HAS A FEW ISSUES I CAN;T FIGURE OUT.
#2 .... TACH DOESN;T WORK AT ALL AND WILL NOT LIGHT UP
#3... OIL TEMP LIGHT NEVER COMES ON .EVEN WITH KEY ON INITIALLY. I GROUNDED OUT THE BULD AND IT WORKS.BUT WHEN LEFT GROUNDED WITH JUMPER WIRE STAYS ON CONSTANTLY,,AND NEVER CUTS OFF LIKE IT'S SUPPOSED TO.EVEN WITH IT RUNNING.
ANY HELP WOULD BE GREATLY APPRECIATED. THANKS
Old Mar 4, 2007 | 05:16 PM
DuneRider650's Avatar
I ride a little here and there......
The tailight is not supposed to be on without the lights on. As far as the tach goes make sure all the wiring is good and that there is power getting to the tach. The oil temp lights i go through allot of....just buy urself a new one they are only like 5 bucks. There are your two fuses under the seat by the airbox lid.
Old Mar 4, 2007 | 05:26 PM
cass's Avatar
O.K. I THOUGHT IS STAYED ON WITH KEY WITH ANOTHER O4 I HAD. I MUST BE WRONG. IT MAKES SENSE IT WOULD ONLY BE ON WITH LIGHTS OR BRAKE. THANKS FOR ADVICE. AS FOR THE OIL TEMP LIGHT , I GROUNDED OUT THE WIRE GOING TO OIL TEMP SENSOR AND LIGHT FINALLY COME ON. IT NEVER WORKS THOUGH WHEN HOOKED UP TO SENSOR. DOES THIS MEAN THE SENSOR IS BAD? THANKS
Old Mar 4, 2007 | 06:25 PM
Default I HAVE O4 BAJA X WITH A FEW ELEC. ISSUES,NEWBIE,PLEASE HELP...
Well, it could be your oil pressure sensor yes. Take it out of the motor and blow it out with compressed air then let it sit and dry out for a night or so....it got mine working again. They are a weak setup though so you may need a new one.
COFatboy
May 2, 2020 12:06 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Jul 30, 2015 09:39 AM
TheHood
Jul 26, 2015 09:51 AM
southbayman
Jul 24, 2015 09:30 AM
