cams
Old Oct 30, 2007 | 08:52 PM
Hickwheeler's Avatar
Default cams
I'm not wanting a drag bike. What cams are others running and liking. I'll need pretty good power off the bottom. I mainly ride the oregon dunes and like doing the holeshots out of the trees. I tried doing a search. Just wasn't finding what I was looking for. It takes forever on my land line out in the sticks were I live.
Old Oct 30, 2007 | 09:56 PM
cynick's Avatar
Default cams
I'm using Web109's and they do awesome for both, I dune a lot and since I had all the work there's nothin i can't climb. Also if you can, get your head and intake ported, it will make those cams, whichever ones you choose, really pay off.
Old Oct 30, 2007 | 10:03 PM
Default cams
thanks for the info. I have a parted intake and tm45. Just haven't changed my info.
Old Oct 30, 2007 | 10:18 PM
cynick's Avatar
Default cams
Cool, since it sounds like you will be removing the head, have it done too, it's well worth the money.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Oct 30, 2007 | 10:39 PM
SANDMAN430's Avatar
Default cams
Well i have the 109's and they are a good choice for sure, but i think they are a little more race friendly. I had the woods a-1 a-2 and they had a better feel to me for the out of the hole torque, they did fade at about 8000 where there still seems to be some left in the 109's. another thought that might help you would be to run some disks on your pipe when i switch from open end cap to the disk the power delivery is a lot better for the hole shots. that is just what i have noticed on my machines. probably the biggest help was the 15- 43 gearing.
Old Oct 30, 2007 | 11:39 PM
650VIPER's Avatar
Default cams
109's for the money. HR2's or 3's if you can get them.
Add compression for the gain down low.
Old Oct 31, 2007 | 01:31 AM
Default cams
thanks for all the input. I don't have the option of adding disk wright now. But I have thought about getting a full system
Old Oct 31, 2007 | 01:33 AM
Default cams
I do plan on a hc piston at the same time.
Old Oct 31, 2007 | 01:43 AM
SANDMAN430's Avatar
Default cams
you can't put disk on the hmf?
Old Oct 31, 2007 | 01:47 AM
Default cams
I thought I said that
