Ds 650 problem
Old Nov 23, 2007 | 10:35 PM
cynick's Avatar
Default Ds 650 problem
When you say no clutch, does that mean when you pull the lever and put the bike in gear it just goes in and stalls the bike? Does the lever feel normal or is the cable busted and the lever is real easy to pull?
Old Nov 23, 2007 | 10:38 PM
Deiti's Avatar
when you pull the lever and put the bike in gear it just goes in and stalls the bike yes
Old Nov 23, 2007 | 10:44 PM
cynick's Avatar
How is your clutch cable, it maybe broke, when you pull in the lever with the bike off does the lever on the engine move also? If it does not then the cable is most likely broke, if it does move then take the clutch cover off to see if any thing is broke on the inside.
Old Nov 23, 2007 | 10:46 PM
Deiti's Avatar
the lever on the engine moves
Old Nov 23, 2007 | 10:49 PM
  #15
Deiti's Avatar
oki tenks
  #16
cynick's Avatar
Pull the cover off where the clutch lever is and check for broken pieces.
Old Nov 23, 2007 | 10:51 PM
  #17
Deiti's Avatar
oki
Old Nov 23, 2007 | 10:59 PM
  #18
cynick's Avatar
Let us know what you find.
Old Nov 23, 2007 | 11:00 PM
  #19
Deiti's Avatar
oki
Old Nov 24, 2007 | 04:02 AM
  #20
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Have you made proper adjustments up at the lever and also down where the clutch cable attaches to the motor?
