Thank you!
Old Jan 6, 2008 | 08:46 PM
Gullo's Avatar
Default Thank you!
Charging problems
I was pulling my hair out for weeks now trying to figure out why my DS wouldn't charge the battery. I tested the system and found the stator was putting out 25 volts ac. The voltage at the battery varied from 10.0 to 13.5. When I turned on the light it would eventually drain the battery. I ordered a new Procom rectifier and it did not solve the problem. Then on Friday night I began to search the web for answers. That is when I found this forum on ATV Connection. I scanned several items and found some great advice about checking the ground. I disconnected the chassis ground, ground the surface down with a die grinder. Holy molly it worked! I had a great ride to day thanks to this tool and your experiences. I hope in time my input will assist some of you.
Thanks Again!
Old Jan 6, 2008 | 09:24 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Default Thank you!
Welcome to the forums. Knowledge does come with experience. Lots of great help and assistance to be found here, and you too will become one of the knowledgable in time. Spread the wealth...
Old Jan 7, 2008 | 01:04 AM
cynick's Avatar
Default Thank you!
Welcome to the forums, there is a ton of knowledge on here as you have seen. Just give it time and you will be like the rest of us.
