Stock Carb Leaking
Old Feb 10, 2008 | 11:54 PM
Dingo2's Avatar
Default Stock Carb Leaking
I recently put my OMR stock carb back on my DS,,,(TM45 for sale)..It started right up, but I noticed at the very bottom of the bowl, gas was dripping pretty good out of that drain/vent...There is a screw there and I tried tightening that up...no help.
Any advice?
Old Feb 10, 2008 | 11:58 PM
cynick's Avatar
Check the drain on the bowl, if it is tight then your floats are set too high. I had this happen on my stock carb once.
Old Feb 11, 2008 | 08:24 AM
DubaiPolaris's Avatar
916 Reaper - Pure Evil Inside!
Your floats just might be sticking. Give the bowl a couple of good taps with the handle end of screwdriver and see it that stops it. If not adjust your floats.
Chris
Old Feb 12, 2008 | 03:20 PM
axlr8or's Avatar
I don't think he's talking about the bowl vent. He's talking about the bowl drain at the very bottom of the bowl. I had the same problem. Long of the short? I just let it go. It stopped when it filled up with mud hehehe.
Old Feb 13, 2008 | 12:57 AM
Dingo2's Avatar
Yeah, I am talking about the very bottom of the bowl, the drain I guess. Whats the fix for that...not really wanting to plug her up with mud though!
Old Feb 15, 2008 | 06:29 PM
Dingo2's Avatar
If it is the bowl drain and NOT the vent, then do I need to replace the bowl?
Old Feb 15, 2008 | 11:11 PM
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
When fuel comes out the float bowl drain:
1- Remove bowl from carb
2- Backoff drain screw 1/4 to 1/2 turn.
3- Flush hot water through drain outlet to backwash debris.
4- Shakeoff excess water or blowoff.
5- Backspray through outlet WD-40, lay flat so it will creep by gravity.
6- In 30 minutes retighten drain screw.
7- Wipe off excessive oil and tests
OMR
micheleLeigh
Jul 12, 2015 02:50 AM
Unzzy66
Jul 11, 2015 10:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
