2007 Renegade vs. 2008 Renegade
Old Jul 8, 2008 | 12:42 PM
Auztone's Avatar
Default 2007 Renegade vs. 2008 Renegade
Can anyone tell me what the differences are between the 2007 and 2008 Renegade 800's? The dealer told me nothing but wanted a little more input on this from someone who might know more. Reason is I can get a smoking deal on a 2007 but if there were some good improvements between the two years then I will pay the extra for the 2008.
Thanks
Old Jul 8, 2008 | 01:23 PM
TLC's Avatar
TLC
According to This site the 07 has more suspension travel and is lighter than a 08.
Old Jul 8, 2008 | 02:54 PM
Krait's Avatar
2008 changes:
- Dual brake levers (2007's had single brake lever)
- Slightly heavier weight (probably due to the changes)
- Faster engaging visco-lock
- Better sealed transmission housing
- Different suspension travel amount
- Different grips
Thats all I know of offhand. The 2009 800's will be '800R', and have 9% more power.
-Krait
Old Jul 8, 2008 | 03:13 PM
Steveo10's Avatar
transmission as in around the clutch....
Old Jul 8, 2008 | 03:50 PM
Krait's Avatar
Clutch housing, transmission housing, belt housing, whatever you want to call it.
-Krait
Old Jul 8, 2008 | 04:01 PM
Auztone's Avatar
Excellent information. Not decided but leaning more to the 2008. The 2009 sounds good with the added power and I guess another color option (Red). But I will have to wait at least till mid August from my local dealer to get one. So many decisions to be made. Thanks!
Cheers
Old Jul 8, 2008 | 09:09 PM
GE4x4's Avatar
The rear trailing arms are different also. If you don't plan on getting different shocks like the X shocks, then it won't matter. But if the X shocks are something in the future, they won't fit on the 07.
Old Jul 9, 2008 | 05:45 AM
Krait's Avatar
Ah yes, I was going to mention that also, the X shocks are wider, and the 2008's have notches to accomodate them. I believe also that the 2008 800 received some engine updates as well, 11% better fuel mileage and smoother throttle response from different EFI mapping, not sure if that was just on the Outlander 800 or included the 'Gade 800 as well.
-Krait
Old Jul 14, 2008 | 02:44 PM
xsinx's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: GE4x4
The rear trailing arms are different also. If you don't plan on getting different shocks like the X shocks, then it won't matter. But if the X shocks are something in the future, they won't fit on the 07.</end quote></div>
Should be said though that you can swap the '07 arms for '08 arms on your Renegade to install the X suspension on a '07. I'm in the process of doing that right now. Arms are 150$ish each.
Old Jul 14, 2008 | 03:08 PM
Krait's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: xsinx
Should be said though that you can swap the '07 arms for '08 arms on your Renegade to install the X suspension on a '07. I'm in the process of doing that right now. Arms are 150$ish each.</end quote></div>
True enough.
-Krait
