i need some help please
Old Jul 13, 2008 | 11:03 AM
ebyers77's Avatar
Default i need some help please
i have had a 2000 ds that i bought new in 2000 and now for some reason the front wheels need to be aligned, so can anyone give me good, easy to follow directions so i can get this done without taking it to a stealership
thanks
Oh btw this looks like a great forum, glad to be a part of it
Old Jul 13, 2008 | 12:00 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Toe out is 1/8 inch greater in the front of the tires than the rear. You should first lift the front end of the bike off of the ground to remove all load, then set it down gently. Make your adjustments on the tie rods, remove load again, recheck toe, then tighten everything back down once you've achieved the desired setting.
Fairly easy task for toe in/out. If alignment is definitely what you're needing then it is done the same way, just more adjustment.
Old Jul 13, 2008 | 12:07 PM
ebyers77's Avatar
not 100% sure what i need, all i know is it does OK on gravel roads but on blacktop it throws you all over the road (left, right) really got to hang on to the handle bars or you will be in one on the 2 ditches on the side of the road
where do i take the measurments from?
also do i need to get the tires set at ZERO before i start making 1/8 toe out, and is toe in better than toe out?
Old Jul 13, 2008 | 01:28 PM
FatHolly's Avatar
Take measurements form the most foreward and most rear position on the tire. I find it easiest to set to parallel first and work from there.
Old Jul 13, 2008 | 02:25 PM
ebyers77's Avatar
so i should get my bars the straightest that i can and than adj. until i get it parallel
than go for the toe out
or is it toe in?
Old Jul 13, 2008 | 03:21 PM
FatHolly's Avatar
Thats what I do. Even if your bars are off by a little it will feel funny, so take your time on that step.
