outlander 800 will not run !!!!!
Old Dec 20, 2008 | 03:27 PM
jrtoy's Avatar
Default outlander 800 will not run !!!!!
ok i plowed the drive ways last night went to start today will not fire at all i just got new plugs going to try them right now. other then that got me help!!!
Old Dec 20, 2008 | 05:20 PM
upnort's Avatar
3 guesses. Kill switch off?? Kinda stupid but have done that before.
May have killed batt, have a meter?
If turns over & is cold may have got some moisture in fuel & froze.
Old Dec 20, 2008 | 09:00 PM
jrtoy's Avatar
well the plugs did not work. pull the fuel line a part got gas there.put dry gas in still got nuthing.
Old Dec 20, 2008 | 10:22 PM
H20's Avatar
H20
Sounds electrical , Do you have spark? Also check fuses.
Old Dec 21, 2008 | 04:31 PM
jrtoy's Avatar
ok got sum spark don't know if it is right. and all the fuses are good. can anyone help?
Old Dec 21, 2008 | 04:34 PM
upnort's Avatar
How is the battery? Plowing using winch can draw it down. Jump it or put on charger, preferably trickle charger. Bring it in to warm up.
If you have "sum" spark that may be trouble.
Did you try starting spray? Spritz it right into carb throat.
Old Dec 21, 2008 | 05:24 PM
jrtoy's Avatar
i tryed spay did not start on it. bat is full charge.i put a heater on for a hour still will not start. any outlander guys out there that can help.
Old Dec 21, 2008 | 07:16 PM
Cardiac's Avatar
You can take all the "shootouts" and put them in one bucket and you won't have beans.
Air, fuel compression and spark and it will run. Process of elimination. You say you have fuel, spark(?), air is a given and you can tell if you have compression generaly by the way it cranks over. Go back to square one and you should be able to find the trouble. Often times we look for unique solutions when the problem is basic. Good luck.
Old Dec 21, 2008 | 09:35 PM
H20's Avatar
H20
Does it fire at all? I would pour a little gas into each cylinder and heat up the spark plugs (at least one cylinder) with a torch then immediately try to start and let us know if it fires or stumbles at all??
If It does not fire at all after you have done that then you don't really have any spark.
Old Dec 22, 2008 | 08:20 AM
Scientist's Avatar
Make sure the battery is well charged as plowing/winching does tend to drain the battery down.. the 800 doesn't have carbs its efi. Does it actually crank? but like the others said sort out the very basics first and then look for the more complicated issues but I do suspect it might be the battery
