o-ring head?
Old Jan 7, 2009 | 08:43 PM
brian 68's Avatar
Default o-ring head?
i am new here so i just wanted to say hello to everyone. i was just wondering if anyone knew where you can get your head o-ringed, or is it even possible? [don't
have a head to look at] thank's
Old Jan 7, 2009 | 08:49 PM
95wolv's Avatar
O ringing a head is often done with high performance mods to the motor, I know several shops that will do it for cars, but I'm sure you could find a good shop that would do it for a quad motor. They mill a groove around the combustion chamber,, and ususally use a soft wire o ring tapped in for the sea, supposed to be a lot more blowout and leak proof than a standard gasket. You can also get gaskets with a wire o ring built in, for a better seal.
Old Jan 7, 2009 | 09:25 PM
brian 68's Avatar
thats what i thought just wondering if any one specialized or at least big enough to be aroung to get replacement rings if needed.the head seal as i remember didnt look o-ring friendly . like i said just curious , i like being able to reuse the ring when trying new parts . sounds good anyway.
1ArmBandit
55
Oct 14, 2015 09:03 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Sep 23, 2015 06:23 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
