ds 650 need help
Old Sep 8, 2009 | 12:40 PM
jprosser89's Avatar
Default ds 650 need help
HOW do u get the rear axle out of carrier on a 2000 650 ds that axel nut on the left dosent come off how do i do it
Old Sep 9, 2009 | 09:10 AM
xFreebirdx's Avatar
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Veteran: Army
Loved
Community Favorite
Do you have a Service Manual for your quad?
Old Sep 10, 2009 | 10:25 PM
justme23005's Avatar
You take the nut off, anyway..
Old Sep 11, 2009 | 01:07 PM
bbyers's Avatar
theirs a C-clip that keeps the nut from backing out or getting loose. You have to take the clip out before you can get the nut off. The c clip is actualy inserted into your axle. You may have to tighten up the nut to make it easier to get to the clip.
Old Sep 11, 2009 | 04:07 PM
Take the small (6mm) nut & bolt out.. turn the big aluminum nut in a few turns.... Dig the wire clip thingy out, then spin the nut off.. you might have to insert a small prybar or screwdriver into the split on the nut to turn it.. tap the rotor off, & the axle slides out..
