05ds650 baja X turning
Old Apr 28, 2010 | 11:59 AM
Chumly75's Avatar
Default 05ds650 baja X turning
Hey guys just got ack from LS OK and need to figure out how to get my 05 baja to turn etter thru the trails. I follow alot of buddies on yfz 450's and do fine till I start to wear out and then I start missing turns as the power just pushes the bike forward. I am wondering if wider a-arms will help or if anyone has any good ideas. Bike is slghtly modified with 14 tooth front sprocket, big gun cdi, t4 exhaust, tm45 with ron woods intake and direct mount filter, and port and polish job. Any suggestions are greatly appreciated.
Old Apr 29, 2010 | 06:53 AM
BasicBajaX's Avatar
Keeps busy in the garage building one thing or another.
Do you got sand tires up front? They may help some but I dont think going wider will help you turn easier... Maybe some adjustments to your suspention would help. If you need some DS front sand tires I got some just sitting in the garage.
Old Apr 29, 2010 | 10:31 AM
Chumly75's Avatar
Yeah I got the double rib ITP's
Old Apr 29, 2010 | 11:32 AM
DSengineer's Avatar
Has been here a long time!
Try taking some of the preload out of your shocks (both front and rear) to lower the stance and center of gravity. This will also slightly widen the front end as the a-arms will now be more parallel to the ground.
MikeyBoyesq
Aug 10, 2015 11:11 AM
Jul 30, 2015 09:39 AM
TheHood
Jul 26, 2015 09:51 AM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
