can am ds 250
Old Dec 23, 2010 | 05:06 PM
titanpride's Avatar
Default can am ds 250
besides removing the spacer and turning the set screw is there any other way to give it more power and speed
Old Jan 6, 2011 | 11:24 AM
dsomonster's Avatar
Sorry titanpride, the only way to get more power out of her is with the Full Power Performance Clutch Kit, air filter kit, slip on exhaust (no head pipe available), carb jet kit, and 14 tooth sprocket.
The Clutch Kit and Sprocket does not add any power, but it makes the little quad much more snappy. The clutch kit basically allows the bike to start off closer to the peak torque range and makes the bike accelerate harder. The 14 tooth sprocket gives the feeling of more low-end torque and it does not affect top speed too much.
I've done tons of research for my wife's bike and there is not really too much you can do to this machine. If you want higher top end speed, you can change to a bigger tire and rim size but you will be pushing more tire weight.
This bike will eventually be my daughter's bike so the 17-21hp we will be pulling out of her will be just fine.
If you find anything more, let me know.
-Ron in SoCal
