Bombardier ds 650 Sprag Bearing
Old Feb 7, 2011 | 10:55 AM
Jrock33's Avatar
Default Bombardier ds 650 Sprag Bearing
I am looking at a 2000 ds 650 that the owner says needs a new sprag bearing. Other than that it is supposed to be in good shape. He is asking 1100 for it. Would this be a good buy, is it easy to fix?
Old Feb 7, 2011 | 11:12 AM
DubaiPolaris's Avatar
916 Reaper - Pure Evil Inside!
It's about $200 in parts. Not really hard if you have a flywheel puller and are mechanically inclined.
If thats all thats wrong, and you do the work yourself, than thats a pretty good deal.
Chris
Old Feb 7, 2011 | 11:45 AM
Jrock33's Avatar
Default ds 650
Is it actually called a clutch sprag? How hard is it to get the timing set right. It is also all apart already I supposedly just have to put it back together.
Old Feb 7, 2011 | 12:03 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Sprag clutch. If it's already apart then it'll be real easy. You have a keyway that can't be misaligned and as long as the key is in the groove your timing is set. Assuming that you cams are aligned properly.
If you have to pull the flywheel for the first time it is a mother. I'd suggest having a torch handy. The gorilla snot that Can Am uses for the flywheel is Grade A stuff.
Old Feb 7, 2011 | 12:48 PM
Jrock33's Avatar
Default Sprag Clutch
It is my understanding that it is all apart and the sprag clutch is out. The guys son took it apart and decided he didn't want to spend the money on the new part last fall. How do I know if the cams are in the right spots?
Old Feb 7, 2011 | 10:05 PM
aceisback's Avatar
Military Rider
While at top dead center the lines on the cam gears will be pointing towards one another and the cam lobes will be facing outboard, intake to the rear, exhaust to the front.
Was the flywheel spinning backwards or what? What led them to believe the clutch went bad?
wendal
Aug 3, 2024 10:03 PM
2quiker
Mar 22, 2022 08:36 PM
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
