2002 DS 650 jetting
Old Mar 23, 2011 | 05:20 AM
rockey07's Avatar
Default 2002 DS 650 jetting
Hey guys
I have been looking on the older fourms for my answer but cant find the exact answer im looking for. I need help with my jetting
Im running a k&n air , ct full system exhause with the 12 disk end cap on it, i have the big gun rev box on it and it a stock carb.
Im running the needle on the very top notch and im runnning a 185 main jet and the jet and the needle is from a dyno jet kit. but i just took it out and it was running real lean but i can't increase the main jet, thats the biggest it says to go on the dyno jet kit. I also got a 175 main jet its an oem jet and people says that its larger than the 185 dyno so im not sure if i should try that one in it or not
I live in ottawa ontario canada
thanks
Old Mar 23, 2011 | 08:58 AM
chrisc321's Avatar
Have you tried adjusting your mixture screw?
Old Mar 23, 2011 | 10:28 AM
DSengineer's Avatar
Has been here a long time!
Needle clip in the very top position is the leanest it can go. You need to drop the clip position and fatten up the midrange. DJ jets run larger # than comparable stock jet. Do a google search and you can find a Mikuni/DJ cross reference.
Have you read through the OMR stock carb mod sticky at the top of this page?
Old Mar 23, 2011 | 10:38 AM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Do the OMR carb mods and drop to the second from the bottom clip position. You'll like!
Old Mar 23, 2011 | 06:59 PM
rockey07's Avatar
I just put the needle 2nd from the bottom and the air fuel mixture screw out 2 turns and still kept the 185 jet in but now it won't start on choke
Old Mar 24, 2011 | 12:16 PM
infantryvet's Avatar
you had to have changed something else,the main wont have anything to do with it not starting,when you changed clip position on needle did everything go back together properly?floats sticking not allowing fuel into carb(needle/seat)?make sure your gettin fuel and start switch is on...i have seen this b4 lol
95wolv
Sep 27, 2024 12:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
