Can we talk about sprockets
I just put on a 15t front sprocket yesterday. Only took it out for a 10 min ride around my work area but it is 1000x better on the low end, feels wayyyy better. Im heading out now for a few hrs of riding!!
I have a 14 on the front. Previous owner did it for trail riding. I have mixed trail and open field/hill riding. It is a good mix for my type of riding. There is still plenty of top end. I also have a 15 tooth still sitting in the package. Has anyone sampled all three sizes? 16, 15 and 14. I'd be curious to know what most people preferred.
i got the stock i went rippin' down a very long, straight dirt road i was at like 90% throttle, the quad got up to speed, stayed there for a few seconds then pinned it and i didn't really feel like i was accelerating, kind of like my clutch was slipping but it wasn't.
long story short with the 16-tooth sprocket very rarely will you actually get up to top speed. Keep in mind everything is stock on my ds650, no mods at all.
#15
You guys are all trying to compare sprocket sizes without even mentioning what size rear tires you are running. The affect of a 20" vs 22" rear tire in terms of gearing is significant. Don't forget tire diam = gearing too...
#16
#18
Well then I would look into upgrading those crappy stock tires before worrying about your gearing. Get a good set of 22"s then gear down appropriately.
#19
For the meat a good combination is 23 up front and 22 in the rear, accompanied by a 15t countersprocket and a 42t out back. Makes for a little more ground clearance for those pesky rocks and roots and gives you better launching capability while maintaining most of your top end.
If you're running a mostly stock bike a couple of good and fairly economical upgrades are the OMR stock carb mods, a Big Gun CDI, and a decent slip on or end cap.
But be warned, once you start it never stops! If you do any of those changes it will lead to a high compression piston, followed by a set of cams, followed by a TM45 or Lectron, followed by some head porting, followed by some stroking......
KEEP IT STOCK.
KEEP IT STOCK.
