Graydon products
Old Mar 22, 2001 | 12:35 PM
jeffnrivercity's Avatar
Hey clif,that sounds like it might be the ticket,I had bought some other brand previously(at ace hardware)some gray looking stuff but I was a afraid use it it seemed like the kinda stuff that would cure hard like a rock.If and when I ever get my tail pipe back from Graydon I will try your method.
THANX
Jeff
Old Mar 22, 2001 | 01:50 PM
Jimmie's Avatar
sorry jeff it's jimg@parrett.net
Old Mar 22, 2001 | 07:45 PM
clif's Avatar
This stuff looks gray,but it's made for mufflers.I believe It contains sillacate,so it can take the high heat! Good luck.....
Old Mar 23, 2001 | 10:27 PM
clif's Avatar
Sorry, but scratch that one!It started leaking the next day.I will be putting my stock head pipe back on. Graydon head pipes SUCK!!!!
Old Mar 24, 2001 | 02:35 PM
  #15
clif's Avatar
The stock head pipe does not even come close to fitting the Graydon. I am so mad at Graydon! They should only have made a slip on instead of charging $400 for a royal pain in he a##.
Old Mar 25, 2001 | 05:05 AM
  #16
CALDS650's Avatar
clif my stock header and Graydon tail section fit just great but I have a 2000 DS650. If Bombardier change the header between the two model years Graydon Proline need this info so they make adjustments.
Old Mar 25, 2001 | 05:38 PM
  #17
ScoobyDFW's Avatar
According to the parts catalog, the header didn't change, but the rear subframe did which could have changed bolt locations.
Old Mar 26, 2001 | 08:10 PM
  #18
clif's Avatar
The connections arenot the same.The stock header is way smaller then the Graydon.when I put them together,theirs a big gap between the two pipes.CALDS650,is this how yours went together?The two Graydons have a tight fit.Also I tried to see how it would line up together,and maybe I am wrong but it was pretty clear that it was not going to work.The stock header was higher then the Graydon.
Old Mar 27, 2001 | 10:18 AM
  #19
CALDS650's Avatar
clif I think I see where we are on different pages. When I say stock header I mean all the way back to where the three springs are. That is the two pipes coming out the head into the two into one collector with heat shield and back to the springs. Sorry for the confusion.
Old Mar 27, 2001 | 11:09 AM
  #20
still have not got my tail section back from graydon,called and they said it was out getting the ceramic coating done probably another week.e-mailed them and gave them a piece of my mind(ok that probably added 3 weeks before I get my pipe back oh well)For the time being I put the stock pipe back on,and modified the tip to get a little better flow,sounds good but feels like the jetting is a little off now.
jeff
