ds650 rear end
Old Feb 6, 2012 | 03:09 PM
quepasa69's Avatar
Default ds650 rear end
I replaced the rear axle bearings this weekend. Still have a little play. I noticed in the parts breakdown That there is supposed to be wear rings in between the bearings and brake and sprocket hubs. Im assuming this is why I still have some play left and probably not to good to run with out them. I think the previous owner had this apart. Where is the best place to get these wear rings?
Old Feb 12, 2012 | 07:53 AM
justme23005's Avatar
since the bearings are tapered, they probably loosened up after you drove it around a little.
I got tired of changing bearings all the time, so I came up with a kit that gets rid of the tapered bearings & uses sealed roller bearings, instead.
Old Feb 27, 2012 | 07:25 AM
MRDS650's Avatar
Canadian and Proud of it !!!
You don't need the wear rings, I have put together a few different DS's without them and it won't make a differance in play. Did you go threw the proper procedure for loading the bearings ? You have to tighten them and loose them a couple 3 times before you set the final torque with the special wrench and a torque wrench.
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
