I also have an oil light problem
Old Mar 18, 2001 | 06:43 PM
BigWaynester's Avatar
I started my DS today and the red light did not go off. ( it was dim for a second ) The engine was cold, it was fine when I put away last weekend. It has plenty of oil. I even tried bleeding it, the red light stays on. What can I try next ?
Old Mar 18, 2001 | 07:21 PM
I just started it up again, and the light stays on dim.
Old Mar 18, 2001 | 08:49 PM
ScoobyDFW's Avatar
I would take that light VERY SERIOUSLY!!! Don't ride it.
I wouldn't keep starting it, but if you do you can shine a light down the opening of the oil tank where you fill the oil and look for oil moving around which indicates you have oil pressure. If you see no oil moving around, there is no oil pressure - don't start it anymore and get it too the dealer.
It could be a bad oil pressure switch or bad wiring (a short). Or it could be a bad or shorted overtemp sensor. These can be easily tested.
Old Mar 19, 2001 | 01:05 AM
sand45's Avatar
HEY DO YOU HAVE AN EXTENDED WARRENTY ON YOUR DS? WELL EITHER WAY I WOULD TAKE IT TO THE DEALER. THAT WHAT IM GOING TO DO IT'S TO IMPORTENT FOR ME TO MESSS WITH AN TAKE A CHANCE TO GRANNADE MY MOTOR!
Old Mar 20, 2001 | 11:14 PM
LUBA's Avatar
The switch is probably bad, water or a wire. I had the same problem. They replaced the switch, never had a problem again.
Old Mar 21, 2001 | 03:01 PM
sand45's Avatar
MY DS WHENT TO THE SHOP TODAY, BECUSE MY RED LIGHT WOULD COME ON SOMETIMES WHEN IWAS NOT GOING VERY FAST.WELL LUBA YOU WERE RIGHT COME TO FIND OUT MY FAN WHENT OUT ON ME.SO IT ALL UNDER FACTORY WARRENTY! THANK FOR INFO
Old Mar 23, 2001 | 12:26 AM
It was a sending unit switch, one of the up dates that came up after I purchaced it. The dealer replaced the part with the up date.
Old Mar 25, 2001 | 10:03 AM
skidog's Avatar
there is a campaign recall for that oil light problem ,bring to your dealer to have the repair done free of charge.
Old Mar 25, 2001 | 10:37 AM
2000DS650's Avatar
BigWaynester, what is the mfg. date on your quad? Mine is April 2000...wonder if my switch needs replaced? Why does Bombardier not send out bulletins to owners about these kind of things? I could make for a little less customer anguish if and when something does go wrong if we had some information. I find it somewhat disappointing that I never heard a single thing from Bombardier after paying over $7,000 for one of their products. Like maybe send out a questioner asking about the product and the dealer. This would indicate a lack of concern about customer satisfaction to me. I like my quad a lot but feel distant from Bombardier. I work in an industry that relies a lot on customer support and satisfaction. Some dealerships don't know what customer satisfaction is. Because of the horror stories I have heard I am very reluctant to take my quad to the dealer for service unless I absolutely have to.
Old Mar 25, 2001 | 05:43 PM
ScoobyDFW's Avatar
Have you seen this post? 2000 vs. 2001 ds650
I did receive an owner survey from Bombardier adn have received a couple notices of updates, but not all of them.
