Oil Filter Housing
Old Mar 30, 2001 | 03:36 AM
BlackHawk's Avatar
I'd say that is one of the best ways you can spend $30 on upgrades for a 2000 DS650. That modification ought to hit the other DS650 websites ASAP.
Old Mar 30, 2001 | 01:46 PM
DSjockey's Avatar
this is the good stuff we come here for
Old Apr 2, 2001 | 10:29 AM
DBLBKB's Avatar
One additional comment to make while we are talking about oil and filters. Be sure to have the 10-hour inspection and oil change done. Also if you are changing your own oil be sure to follow the operators guide on bleeding the oil circuit before putting the filter in. I read this twice, and then found it was easier to just bleed the system and not start it then go back and bleed it. Be sure you have an impact driver for that screw, it is in tight. I know this from experience, you do not want to ride with the red light on, it does not take long for the crank bearings to be damaged with no oil. FYI hope this helps.
Old Apr 3, 2001 | 03:42 PM
Crashfirepm53's Avatar
Anyone have the part #'s for the three items??
Old Apr 3, 2001 | 06:49 PM
  #15
Knutz's Avatar
filter cover part #711610230
screw part #205063044
I don't have the filter # but your dealer should have filters in stock if he does the 10 hour service on a 2001 model. If he doesn't know the difference, he must not change the filter like he should. I found out that my dealer didn't know about the difference!
Old Apr 19, 2001 | 09:47 PM
  #16
DSjockey's Avatar
This is great, the 2001 filter costs $8, 36 cents more than the 2000 filter
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
